Why does my air cleaner cover keep falling off?
2011 FXDWG with V&H staggered short shots and a screaming eagle stage 1 intake.
I'm on an epic (to me) 21-day ride touching all 48 lower states. It's Day 14.
In just about 6,000 miles since we left home, the center plate of the K&N filters I use has failed three times. The plate that bolts to the intake has the nut on it that the bolt that holds the cleaner cover on threads into, and the metal around the nut is fatiguing.. Eventually it breaks, and the cleaner cover - nut, bolt, and a small circle of metal - comes off.
We left Columbus, GA on May 2. It first failed outside Durango, CO. The HD shop was minutes from closing when I rolled in, so I replaced the filter myself.
When we had a scheduled oil change in Sacramento, CA, the service tech noticed the metal was failing, but hadn't broken al the way off. So the shop replaced it.
Then yesterday, somewhere on the high plains in Wyoming, it fell off again.
I'm using a t-shirt to cover the filter and gaping hole for now, but we have another service opportunity in Ipswich, MN in a couple of days.
I'd post pictures, but I haven't figured out how to upload photos from my phone to photobucket yet.
Anybody ever heard of such a thing?
And if you're curious about the ride, you can read, look at photos, and watch videos (including live streaming from the road) at www.rideformiracles.com
That's exactly it. It's the metal plate that has the threaded nut on it that is failing. The bolt is secure in the nut.
Maybe you're over tightening it and stressing the metal around the bolt.
Put a little blue Loctite on it and don't over tighten it and it should be fine.
I run the same filter on a couple of my bikes and have never experienced a problem like that.
All nuts and bolts on a harley must be torqued to there recommended specs, if you overtighten it will possibly stress and break and if you under torque it will loosen and back off. Plus everything i install has loctite and proper torque spec as to manufacturers recommendations. Hope this helps you and good luck
This is the most likely culprit. An accurate low-range torque wrench for the cover is your friend.
Next time you remove your cover, make sure the rubber piece, that goes between the cover and filter is still there. As the others suggested try some locktite and torque it. My only other thought is, is your leg hitting it or laying against it? Hope you get this figured out.
Check out the website at www.rideformiracles.com. we are streaming live video from the road as we roll down the highway. We are in Wisconsin right now. We should be in Milwaukee sometime tonight.
