What is this and can I remove it?
05-18-2014, 08:29 AM
So what is this gray bracket and can I just remove it? There are three screws that hold it on under the case.
05-18-2014, 08:35 AM
Yes you may.
I used a torx bit and a wrench to turn it on the one...the others I could get with a ratchet and wobble extension.
-ps-
I want that same timer cover!
05-18-2014, 08:48 AM
but don't discard it. I had to buy one when I got my supertrapp exhaust
05-18-2014, 09:04 AM
I use it to hang my gremlin bell
05-18-2014, 09:23 AM
I have Vance n Hines exhaust on my bike now but I'll keep it just in case. I have the timing cover and derby cover that match. Bought em at the local hd shop. Do I need to put the screws back in?
05-18-2014, 09:37 AM
Quote:
Originally Posted by
milesvdustin
Good idea to leave screws or plastic plugs in place to defend against muck and crud from corroding the exposed threads....
05-18-2014, 07:28 PM
I painted mine flat black and it is hardly noticeable now.
05-18-2014, 08:04 PM
Id stick the screws back in with some never seize. When I pulled the oem plastic plugs to mount my hwy pegs the treads were wet and had surface rust.
05-18-2014, 08:34 PM
It's only the muffler bearings bracket, ok to remove.
05-19-2014, 12:48 PM
Well my shitty torx bit stripped out. Looks like it's staying put for now.
