Punch-Up Bub
Punch-Up Bub
HAHAHAHAHA
OK, bike has been stripped of invisible paint, ****** have been removed, homemade bars have been trashed (not reliable at all, bent on the first speed bump), **** has been cleaned off of the seat, the t-rex/syn combo has been drained and recycled through the storm drain in front of my house... All should be well now! I will upload my pictures by the end of today although I didn't take pictures along the way so these first ones will be from when I picked it up and then how it looks as of 24 May 14.
o Purchased the bike in May '13 / took delivery July '13.
o Bought some parts but didn't want to stop riding it.
o Finally stopped being a lazy **** and did some stuff.
o J&P Cycles Shorty Riser Set
o J&P Cycles Handlebar Riser Bolt Set
o J&P Cycles Polyurethane Riser Bushings
o Drag Specialties ##" Throttle/Idle Cables
o Drag Specialties ##" Clutch Cable
o Magnum Shielding ##" E-Z Align Front Brake Line
o J&P Cycles Black Brake Lever
o NAMZCCP Wiring Extensions
o H-D Diamond Black Hand Grips
o J&P Cycles Oval "Shaker" Floorboards
o Floorboards installed.
o Air cleaner cover Plasti-Dip'd black.
o Apes installed
o Front signals removed.
o Reflectors/badges removed.
o Remove stock heat shields and wrap headers/mufflers.
o Install aftermarket exhaust.
o Install Vance & Hines Fuelpak FP3.
o Install H-D Crossbones 17x6" rear rim w/ 200mm tire.
o Install some sort of detachable windshield. (???)
o Chop the fenders. (???)
o Install some sort of solo seat. (???)
o Paint/powdercoating.
o BACKSTORY.
o 2013 Harley Davidson FXDBP w/ 103".o Purchased the bike in May '13 / took delivery July '13.
o PARTS LIST.
o Burly 16" Narrow Apeso J&P Cycles Shorty Riser Set
o WORK COMPLETED.
o JUL 13 - 24 MAY 14.
o Grips installed.o Floorboards installed.
o Apes installed
o GOALS.
o SHORT TERM.
o Install J&P Cycles Handlebar Riser Bolt Set.o Remove stock heat shields and wrap headers/mufflers.
o MID TERM.
o Install some sort of luggage. (???)o Install aftermarket exhaust.
o LONG TERM.
o Install springer front end.o Chop the fenders. (???)
Last edited by timedrapery; 05-24-2014 at 08:35 AM. Reason: Updates... (24 May 14)
