On that one when I remove the cover, first thing I do is screw the screw back in it's place so I don't lose it.
Should be standard paractice anytime you can unless something prevents you from doing this.
Something else I do if taking off a cover with multiple bolts is get a piece of cardboard and draw out a crude sketch of it and X the bolt holes.. then I poke a hole in each X and as I remove each bolt I put it in it's place.... helps keep them all in order since many times they are different lengths
That`s the first thing I usually do and I thought I did.
Here`s another one, I can`t find my seat bolt!! I bet it`s with the battery cover bolt. Luckily, I have 3 of them
DO NOT touch your motor mount or suspension bolts!!
