well guys made the 120 HP club
well got the ole scoot tuned up last weekend. the auto tune only had the tune close in the upper rpms. the bottom and mid range was too rich. and the timing as Dan stated was very conservative. after he got all the adjustments where he wanted it. he pulled a run. and stated the old thunderheader dip. at 2200-3200
I asked if he had any luck with bending the tabs on the baffle he said it works on some. so he bent all four tabs in to the outside case tight and said we will see if this makes any difference. did another pull the tq came up. he made some fuel changes and timing and it came up and moved forward to 3000-3300 and he went to those cells and made some more changes and did another run and the dip was gone. did 3 more runs in 4th gear with 123HP/119 TQ. Dan told me i could improve those numbers with a better exhaust. and suggested the supetrapp 2 into1. that is his go to pipe for consistency. has proven to produce the highest numbers in all the two into 1 that he has tried and believe me there was alot of facts to prove it. talked to ken at dynojet and he told me my numbers would have been alot higher in a 6 gear pull.and there is a formula to figure that out and is going to let me know what it would have been in high gear. so apples to apples will compare to others that there dyno runs were done in high gear.
alan i saw quit a few sheets that were run against other pipes bassani,d&d, propipe, rb racing etc,etc just to name a few that were tuned and than the supertrapp installed and tuned made considerable better torque across the entire power band. im talking on big bore builds not stock bikes. the only new pipe that i saw out at tuners was the new rush wrath that made nice numbers and it has a unique sound. on a built up engine.
don't know if its for me alan did like the sound of the rush!!
