Miss the odd shift
That's about the only other thing other than checking the oil level.
How many miles is on the bike?
If you feel it hit neutral and clunks hard when it goes into gear. First a clutch adjustment like other has said, Change the transmission fluid and inspect for metal on the magnet.
Did this happen all at once or did you just get the bike?
Bike's got fresh fluids and clutch adjustment a month ago. Had the primary cover off as well for a general inspection (just got the bike) everything looks good inside, 20k miles on it. Compensator looked fine visually. I didn't adjust the chain tensioner, maybe that needs a check? It is a little difficult to find neutral. Never missed any shifts until this last week or so. Doesn't appear to be a chronic problem, more like something's out of adjustment. It's weird, my previous bike you knew right away when you missed the shift, didn't get that solid clunk. This one feels like it shifted, but then you're in neutral. Doesn't seem to happen when hard on the throttle, but only when putt-putting around town.
