Fuel Pak question - help please
I've got an 06 Street Bob which I've fitted a Screaming Eagle air cleaner, V&H straight shot slip ons and the first version of the V&H Fuel Pak to.
It sounds a lot better than stock but I'm never really sure if it goes that much better, and it has that annoying popping when you close the throttle. I believe that was fixed with a later software version on the FP, but being in the UK I've apparently got to send the FP to Sweden to get the software updated so never bothered.
Anyway, the point of the question is, if I dump the FP and just run the bike with the air cleaner and slip ons, how is it likely to run?
It's a UK bike which has the factory alarm fitted meaning there's hardly any room under the seat for the FP, and I'm fitting the small LED indicators which have a control module that also has to be squeezed under the seat somehow. I'm pretty sure I won't fit all that stuff under the seat, so if the bike will run ok without the FP that might be the one to have to go. I'm much more concerned about it running well than going faster so if I can manage without the FP then I probably will.
Thanks in advance (I hope)
06 w/ FP
I'm running a similar set on my 06 SB. I have the V&H side shots with the quiet baffles installed an HD open air cleaner w/rain sock. I too get some decel popping.
Recently cleaned out the intake and checked plugs, seemed to help. Also had the throttle cables replaced, old ones got sticky. I've installed some SE wires and need to pick up some SE plugs to match. Then I'll see how that goes.
I would not remove the FP as the bike may run hotter. Double check your settings? hope this helps.
