Starting to mod/change my FXDWG
Ding....Ding........................Ding! We have a winner!
Better lower end and a carb, are the primary reasons that I wanted the pre-03.
I'll be sticking some gear drive cams in it one of these day, but the chain tensioners are so easy to inspect and change out....I'm in no hurry.
If someone is going to install gear drive cams, the later lowers usually need to be overhauled before you can do the cams.
The best overall cure for the "cam tensioner" problem is to install gear driven cams.
The later model tensioner system helped, but only increased the service life of the tensioners rather than actually curing the problem.
I strongly prefer a carb over EFI on a motorcycle, so with those parameters in mind 1999 thru 2002 are the best bikes for me.
For the guys who trade their bikes in every 45 minutes...It doesn't matter a bit.
The pipes will be coming off and going up for sale/trade some time this winter and the wheels will be traded and sole this winter too.
I'll contact you when the wheels and pipes are ready to go.
I'd trade the pipes for a decent 2 into 1 and I'd trade the wheels for a stock 19" front and 16" rear cast wheels.
I've also got lots of chrome covers and other do-dads that were on the bike when I bought it. (The previous owner was a chrome freak.)
I will be getting rid of the chrome swingarm, the bars, risers, switches and covers, handlebar mounted tach and lots of other stuff are on the way out.
