Front Signal Wires
Front Signal Wires
I have a 2014 Street Bob with Apes. I want to relocated the front turn signals from their factory location to the forks. I noticed that this model has the turn signal wiring inside the wiring looms going to each bar, not separate anymore. So, whats everybody doing out there with the signal wiring? Are you cutting and just fixing up new wires after the signals are on the forks, or removing the factory wiring from the main looms going to each side and run them separate like we would have done in the day? Help!
I'm not using their kit but I am going to use their plugs (73153-96BK(x2) and 73190-96(x6)) and their instructions.
http://www.harley-davidson.com/en_US...ts/-J04390.pdf
So I decided to take the controls apart and just see what Im dealing with. I found that the 2014's wiring from the signal goes straight into the switch then from there into the main right and left wiring loom into the bars and so on. In the old days you could just unplug the signals under the tank and pull the signal wiring out at the top and then relocated, change switch out or whatever. I ended up clipping the wires at the switch, relocate the signals to the fork sides, then run a three wire loom from the switch to the light and wire tie that loom to the outside of the bars. I used strobe light looms so the color is grey. It looks OK. I have a new set of signals with black wiring coming then I will unsolder the wires from the switches and run the black wiring ones. Wonder why Harley changed the wiring on the front signals?
