Let's talk tensioners!
If you guys haven't watched this video, please take a minute. The M6 tensioner actually moves back and forth while running. Even it looks tight, not necessarily mean it is too tight while running.
M6 BT-07 Primary Chain Tenstioner -Installed - YouTube
That's what I was thinking too. Take the tension off ( when spring compresses ) and where does all the slack go? I think that's why the Baker unit is a better design, or the welded stock unit.
Been following this discussion for the past few days not only for interest but also because of the input from the well-respected contributors on this forum. As such, I was swayed to purchase the Hayden M6-BT07 over the Baker 177-67K because of the easier install.
Upon opening up the primary I discovered that the OEM auto-adjust unit was functioning as designed, that my chain's slack was within the specified range and not overly tight at all - mileage is currently just under 20K. I decided to leave well enough alone ('if it ain't broke…') and put the Hayden in storage for possible future use.
For reference, I tend to ride conservatively, and only yank on the throttle every once in a while for fun. If you ride the same way then chances are your chain will be in a similar condition as mine. Hope this helps.
The problem I have the the Hayden is that the newer bikes have larger motor sprockets so the chain needs to wrap more around the tensioner. Since the Hayden has a smaller shoe it seems to have more front / aft / downward forces on the shoe. They don't seem to be wearing as well as the early ones..
those of you that are welding this, where are you welding it? i can weld this sucker no problem just not seeing where would be the ideal location to weld up the stock one. just set the chain slack, mark it and put on tacks? is that what your doing? i would rather weld a bead on it but looking over the stock tensioner i am not seeing where this would be best
