Keep this exhaust or buy new
Old 07-31-2014, 08:59 PM
JohnnyRebKY's Avatar
JohnnyRebKY
JohnnyRebKY is offline
Default Keep this exhaust or buy new
2002 fxdwg carbureted twin cam or " Twinkie". I think it sounds pretty darn good for a Twinkie.
Still has the original exhaust accept for the SE II slip ons. They are gutted out with a home made baffle welded in. Just a washer to create some back pressure. I think it sounds classic harley all the way. Problem is all the clamps are getting rusty and the crossover pipe is looking bad and making a pinging noise like something is rattled loose in the crossover. Basically it's seen it's better days since it's near 13 years old.
So keep it....or short shts....or big shots
Have a listen before you advice
Old 07-31-2014, 09:38 PM
fxdlx's Avatar
fxdlx
fxdlx is offline
You can get a new retaining ring and inter-connect gasket for your stock head pipes. Also some times you can find nice head pipes cheap in the for sale sections. For the SE mufflers if they're the cycle shack type you can open the spoon baffle to match your engine breathing requirements and get more sound out of 'em. It's very hard to beat the performance of stock head pipes with properly set up SE mufflers.
Personally I don't like the whistling sound from washers on bolts.
Also I would turn up the idle to at least 950.
Old 07-31-2014, 09:44 PM
JohnnyRebKY
Post
That's cold idle. It goes a little quicker once it's hot.
Jeremyn21
Exhaust System Topics
02-17-2019 09:02 PM
W1ldC4t
08-01-2013 06:03 PM
FlaDresser
10-30-2011 07:21 AM
colonelangus1
02-10-2011 10:54 PM
hoz88
11-28-2007 11:32 PM
Quick Reply: Keep this exhaust or buy new
