Transmission Side Cover Install???
Hey guys, I'm swapping out my tranny side cover and, for any of you that have done this, I'm sure you know rethreading the clutch cable into the new side cover is...
Anyone know of a technique to get this damn thing on!?
So far I've held the clutch cable still and tried rotating the cover around the thread but it just never bites. It's just hard as hell to find the right angle of the thread........
Battled mine for a while, walked away & when I tried again it grabbed on the first try. New clutch cable turned out to be too short so I had to repeat the process again 2 days later. Again, went in very easy. I think it's just a matter of slight variations of degrees. Is your clutch adjuster backed off allowing cable sleeve to rotate freely?
Yup, the adjuster is backed out to give some play on my end. I read on this a bit yesterday and everyone else had said it just takes time due to the weird angle like you're sayin. I figured that was it so I went at it for 20 minutes and said F*** it.
So Sisson, you sayin that the thread was a little outta whack and once you tapped it, it was fine?
Ya gotta hold yer mouth juuuuuuust right. Odd, I have never had a problem with this! Just dumb luck! Take yer time, and if ya get pissed...go have a coupla beers and smile next time ya try! Good luck!
Oh! Take a really close look at the starter threads on the clutch cable collar! Sometimes they get folded over during shipping! If they are buggered up, use a small flat bastard to dress them! Be sure to watch your *****...there are 3 of them ya know!
I just went through that two weeks ago with about 20 tries at it, stood back popped a Blue Moon and really looked at the angle that it has to go to thread on, held the cable firmly and started threading the cover on, it went on the first try, ran it about 4 threads set the cover down and finished the Blue Moon.
