Dyno Charts This forum is for posting of your Dyno Charts. You will use a prefix to designate your Cubic Inches. When posting please include all model year, Cubic Inch and modifications in the thread title and in the body when posting your Dyno Charts.
121 + XXX": S&s 124" lc - se 58 - fatcat
Old 02-02-2017, 04:08 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
09 YELLOWBIRD is offline
Nice work Chad!
I'm almost ready to come see you, my heads are done and will be sent home soon!
YB
Old 02-02-2017, 07:36 PM
billib1954's Avatar
billib1954
billib1954 is offline
Very good Chad, will be over to see you soon to discuss my next "maintenance". (That's what I tell the wife anyway, "maintenance is expensive on these new bikes")
Bill
1 2 many (09-08-2021)
Old 02-07-2017, 02:32 PM
tommyglide's Avatar
tommyglide
tommyglide is offline
Originally Posted by Wide Open Cycles
Here's the
comparison.
Red line is the 124" LC crate with the Dragula I pipe
Blue line is the same crate with the Fatcat
Oddly enough, same 2 pipes except the Softail version on my 107, and the results were reversed.
tommyglide's Avatar
tommyglide
Duplitious post
Last edited by tommyglide; 02-07-2017 at 02:34 PM. Reason: Double post however the hades that happens
Old 02-07-2017, 02:50 PM
Wide Open Cycles's Avatar
Wide Open Cycles
Wide Open Cycles is offline
Former Sponsor
Of haven't tuned any Softails with the Drago's pipe yet. I will say the D&D's have worked well for me on Softails though.
Old 02-07-2017, 02:59 PM
Bowhunter61's Avatar
Bowhunter61
Bowhunter61 is offline
I looked at the D&D exhaust, for my 124 they actually recommend the D&D Boarzilla, the FatCat is listed for up to 113" motors.
So for your 107 the FatCat maybe right in the sweet spot.
Old 02-07-2017, 03:38 PM
tommyglide's Avatar
tommyglide
For certain not a thing wrong with what the Dragula did for me, just at that time I was being a bit of a pipe-aholic. What was surprising was how well the Softail headpipe and Kromewerks hp+ slipons did against both 2/1s.
Old 02-07-2017, 04:16 PM
lightweight bob's Avatar
lightweight bob
lightweight bob is offline
Default Another S&S 124" LC
I do a lot of S&S crate engines, here's 1 I just finished up.
S&S 124" LC crate
SE 58mm TB - 5.3 inj.
SE stage I A/C (I milled out to fit the 58mm TB)
Fatcat 2:1 (Perforated baffle)
Barnett +1 clutch, SE heavy spring, AIM 95 lock up
I have the same build on another bike that th owner is putting break in miles on, He's running a Dragula I pipe, I'll post his results when I get it tuned.
Here's some similar work with TTS & Borzilla on post #5237 https://www.hdforums.com/forum/touri...ggers-524.html https://www.hdforums.com/forum/attac...ers-dysart.jpg
Old 02-07-2017, 04:33 PM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,953 Likes on 1,685 Posts
Much difference in loudness levels between the D&D and the Dragula?
Old 02-07-2017, 05:39 PM
tommyglide's Avatar
tommyglide
Dragula sounded very good, Fat Cat has a different tone for sure, and louder. Both appealing to my ears.
Quick Reply: 121 + XXX": S&s 124" lc - se 58 - fatcat
