TECHNO RESEARCH RACE TUNER QUESTION
Old 12-17-2007, 06:11 PM
strengthin1's Avatar
strengthin1
strengthin1 is offline
Default TECHNO RESEARCH RACE TUNER QUESTION
I had a Techno-Research race tuner put on my Girlfriends'07 Dyna per their recommendation and the shopis having problems finding it's sweet spot. Bike was backfiringwhen decellerating/gearing down.Has been on the Dyno and still can be going forward. They're telling me it's just a matter of finding the "right map setting". She presently has a Stage 1 kit and Rinehart pipes. Any one else seem to be having the same problem? Any feedback would be appreciated. I know the mechanic is a straight shooter so it's just a matter of getting it dialed in. Anyone else have any experience w/ this race tuner? Thanks!
Old 12-18-2007, 09:09 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Default RE: TECHNO RESEARCH RACE TUNER QUESTION
I have a SERT not a techno but if the bike is popping on decel then it is probably still running lean as that is a major symptom. My lean popping was reduced to almost nothing by increasing both air and fuel settings in very small increments until the popping went away. I did it myself with my laptop because my dyno tuner couldn't get it right.(BTW it took me a weekend and about 20 2-4 mileruns with the bike up to full operating tempto get it optimized). If you dothis make certain to check your spark plugs to be certain they don't have black deposits which will indicate you are running too rich. You should be able to wind that motor from 2000-5500 rpm and decel all the way back down to 2000multiple times and get no popping. You will know when you are there.
Kyle Washam
01-16-2019 11:57 PM
soberjoe
04-03-2016 09:48 PM
kdubcr250
01-31-2010 08:48 PM
Wolfx
28
07-20-2009 07:31 PM
lobe50
03-13-2006 02:45 AM
Quick Reply: TECHNO RESEARCH RACE TUNER QUESTION
