Auxiliary Lighting
Old 09-21-2015, 06:16 AM
rstlnfan1's Avatar
rstlnfan1
rstlnfan1 is offline
4th Gear
Default Auxiliary Lighting
My wife has a 2014 harley fatboy installed an Auxiliary brake/running/ turn signal conversion kit part #69462-06D its a direct plug in.The turn signals light up but never get brighter as the brake is applied also the tail light never brightens. When u put a turn signal on they flash but when you turn them off the light goes completely off then comes back on. I am thinking i might have a bad electrical part and need to replace. Any help would be greatly appreciated. Thanks
Old 09-21-2015, 11:16 AM
enodrano's Avatar
enodrano
enodrano is offline
Did you change the bulbs? I think the kit will work with the OEM 1156 (Single Filament) bulbs, but I believe 1157 (Dual Filament) bulbs will also work, and fix your concerns. Also, if you get new bulbs make sure they are CAN-BUS compatible.
Old 09-21-2015, 08:38 PM
rstlnfan1's Avatar
rstlnfan1
4th Gear
Thanks will give it a try and see if it works
rstlnfan1
09-20-2015 06:32 PM
twofish
Softail Parts
10-13-2011 08:42 AM
oneshotdog
04-21-2011 10:32 PM
titus3:5
10-06-2009 11:07 PM
jamesf0622
05-21-2007 10:52 PM
Quick Reply: Auxiliary Lighting
