Help with headlight low beam issue
Old 10-27-2015, 02:37 AM
Mixter's Avatar
Mixter
Mixter is offline
Default Help with headlight low beam issue
5-3/4 Inch Billet Headlamp 68593-06 Was recently installed by my Indy. Rode it for a few days and the low beam went out. Hi beam still works. Tried swapping out several bulbs and still only the hi beam works....no low beam. Any ideas what could be the problem?
Old 10-27-2015, 08:32 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
A wire has come detached as a guess. Go back to your indy, he'll probably go straight to it.
Old 10-27-2015, 01:49 PM
Mixter's Avatar
Mixter
Mixter is offline
Thanks!
Old 10-27-2015, 01:55 PM
shorelasHD's Avatar
shorelasHD
shorelasHD is offline
Received 2,858 Likes on 1,270 Posts
Pin probably fell out of the connector. Bring it back, probably take the indy 2 minutes to fix. And while you're at it, consider an LED lamp if you anticipate doing any riding at night...will also make you WAY more visible to the cages!
Mixter
10-27-2015 03:24 AM
fenmore
08-08-2015 09:08 AM
PeacemakerOL
06-09-2014 02:48 PM
MichiganDave
07-25-2012 09:01 PM
HTRAUD
03-18-2007 05:21 AM
Quick Reply: Help with headlight low beam issue
