05 Sportster turn signal fault
Old 07-27-2016, 12:20 PM
Kris516's Avatar
Kris516
Kris516 is offline
Stage II
Default 05 Sportster turn signal fault
I just bought a 2005 sportster 1200c and the turn signals are acting up. The left rear has never lit the left front will light normal then flash fast. The right side works fine sometime and other times it won't work at all. Sometime when I hit the right side all 3 light. The other day the left wouldn't cancel until I pulled the fuse. I don't know if I'm dealing with separate issues or a ghost. Just wondering if anyone might have some insight?
Old 07-27-2016, 08:35 PM
Harleycruiser's Avatar
Harleycruiser
Harleycruiser is offline
If your bulbs are good then check the wiring under the rear fender.
Your tms is telling you that you have a bulb out.
Old 07-29-2016, 06:15 PM
Kris516's Avatar
Kris516
Kris516 is offline
Stage II
Four broken wires under rear fender. Thanks for the help all is well now
syizm
06-06-2016 11:41 AM
tomnick
04-08-2012 02:12 AM
05SportyCustom
11-09-2011 01:00 PM
xsivelybad
08-25-2007 12:27 PM
papaschilling
12-30-2005 09:33 PM
Quick Reply: 05 Sportster turn signal fault
