Load equalizer question please help
My 2005 Ultra has a kuryakyn panacea led taillight with the proper load equalizer. I found out that I will need another load equalizer for the front LED turns I just installed (they flash irradically), because the Kury is only good for the rear. Custom dynamics (front turn brand) sold me a equalizer that will take care of all 4 turns. Has anyone else had this combo? How would I install a second equalizer? Will I loose my flashing brake light?
The new Custom Dynamic load equalizer should go in line with the panacea controller connected to the wire harness going to the fender.
You would need to read the instructions to determine which side of the Kury controller the equalizer should be installed.
If you are using the resistor load equalizer with the Kury unit now, you can likely remove it when you install this new CD equalizer.
If in doubt ask custom dynamics they should be able to confirm connection.
Just an update. I got the Custom Dynamics unit installed "upstream" of the Kuryakyn unit. Everything works as it should.....Brake light retained all its customizable features.
I tried installing just the CD unit, and lost my brake light flashing, rear turns acting as brake lights, etc. The CD unit ran the led turns and brake light as it should, but I wanted the added features of the panacea brake light.
Thanks for all the help guys.
don g
06-21-2013 12:12 AM
