Brake Light Flasher
Old Mar 20, 2016 | 11:40 AM
TwoBlue02's Avatar
TwoBlue02
Default Brake Light Flasher
I want to install a flasher - want the best one that at the same time is the easiest to install.
Suggestions?
Old Mar 20, 2016 | 12:41 PM
cmc seabee's Avatar
cmc seabee
Check out Custom Dynamics. They will have what you want.
http://www.customdynamics.com/
Old Mar 20, 2016 | 01:11 PM
kishstl's Avatar
kishstl
I did a full Custom dynamics LED run/turn brake combo on my rear fender. Also bought the LED tri bar light which you don't necessarily have to but all of it was a breeze to install and works great. Tons of flash options and super bright with the LED's.
Old Mar 20, 2016 | 01:13 PM
Olie's Avatar
Olie
I just installed the Custom Dynamics Smart Triple Play, tour pack conversion kit and LEDs for the entire rear of the bike. The triple play allows you 10 different flash patterns to choose from and even goes as far a allowing control over what lights flash. Definitely worth looking into.
Old Mar 20, 2016 | 02:18 PM
CVO SG's Avatar
CVO SG
Yep, I'd recommend calling CD and telling them what you have and want. They'll fix you right up. I found their website product descriptions to be confusing at times. Bought mine thru my HD dealer and both the parts guy and myself thought we picked right part from the CD catelog. When it didn't work as expected, a call to CD cleared up our confusion.
Old Mar 20, 2016 | 02:30 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Just make the full trip and buy a Bright *** Light and watch the cages give you more space.
Old Mar 20, 2016 | 02:38 PM
EG-2006's Avatar
EG-2006
Something to consider-I had a run/brake/turn unit for a few years. The turn signals were on as running lights and got slightly brighter when I applied the brake. Recently had some comments from guys I ride with that with the turn lights on all the time it was not easy to recognize when they got slightly brighter when I applied the brakes. So I replaced it with a turn/brake unit. Now the turn signals are off until I apply the brakes. Much better setup in my opinion and in the opinion of those that I ride with. I also have a brake light flasher connected to the brake light only so when I apply the brakes the turn signal lights come on and the brake light flashes 4 times before it comes on steady.
Old Mar 20, 2016 | 05:53 PM
gpeake13j's Avatar
gpeake13j
+1 on the Bright *** Lights. Cars stay waaaay back now.
Old Mar 20, 2016 | 07:35 PM
ShovelEd's Avatar
ShovelEd
Double Tap
Old Mar 20, 2016 | 07:36 PM
ShovelEd's Avatar
ShovelEd
I've had hyperlites on my last two bikes.
