Aux Switch
Old 04-14-2014, 03:33 PM
Rumble Bee's Avatar
Rumble Bee
Rumble Bee is offline
3rd Gear
Default Aux Switch
How and where do you hook up wiring for something that you want hooked up to the aux switch? 2013 Electra Glide
Old 04-14-2014, 04:05 PM
semelsje's Avatar
semelsje
semelsje is offline
6th Gear
Default Think I found it
I asked the same question for connecting a GPS to my 2010 UC. Didn't get any real answers, so I think I've finally figured it out between the owners manual and the shop manual. If you pull the seat there will be a empty connector just forward of the battery box, there should be an orange wire in this connector that is controlled by the acc switch. I won't be able to confirm this until Thursday when I get a chance to go back into my bike. If you aren't in a rush, and I'm correct, I'll put some pictures on this forum. The manuals also state that you should be able to get the connecter load side plugs from the Harley dealer - We'll see.
Old 04-15-2014, 05:56 PM
semelsje's Avatar
semelsje
semelsje is offline
6th Gear
Default I did find it.
Ok, I did find the right connector and I also blew the 15 amp fuse while I was checking out the leads. There should be three attachments to this reply. One of them shows the capped connection as it looks when you take the seat off, dead center in the picture. The second shows the same connection without the cap showing 4 male connectors inside the connection. The last one shows the HD part I bought to make my hookup. It turns out the part I got really is a splitter so you can hook up 2 accessories instead of just one, I'm sure there is another part that allows you to just connect one. My plan is to cut off the two new connectors and wire in my GPS to one of the set of wires and just not use the rest. Hope this helps you out some. The best I can tell from the four connect points, two of them are controlled by the accessory rocker switch, one of them is hot all the time, and one is ground. So, I'll be using one lead controlled by the rocker, and the ground. No, clock device or anything else that needs to be powered all the time on my GPs.
Attached Thumbnails Aux Switch-capped-connecter.jpg   Aux Switch-cap-removed-2.jpg   Aux Switch-what-i-bought.jpg
semelsje
Electrical/Lighting/Alarm
04-20-2014 05:07 AM
sgdiesel
02-06-2009 01:50 PM
Pastor John
01-29-2008 05:24 PM
TickTock
05-02-2007 10:01 AM
ndotken
12-29-2006 08:19 PM
Quick Reply: Aux Switch
