Oil Leak
Oil Leak
I have an oil leak in my 06 Deuce but I can't see exactly where it’s coming from. It is not the original motor and has leaked since my builder finished it. I would take it back to him but he's hundreds of miles away. The leak is coming from the back of the rear cylinder behind the oil tank. There is something with electrical wires attached to it in that area and I think that's where the leak is. Can someone tell me what that thing is? My guess is its some kind of sending unit. Thanks for any help you can give.
Post a picture and we can pin it down.
Oil Leak
If the leak is on the right side, my guess is the elbow hose that goes from the tank down to the drain plug. The new replacement hose is one piece versus the factory 2 piece hose that came on the bike.
Kind of bitch to get at, but can be done without removing the tank. I used a tin snips to remove the crappy Harley clamps and used worm clamps with the new hose.
Also, be sure to drain the oil before removing the hose.
