2012 Oil Consumption
Old 10-06-2014, 04:45 AM
Beezr's Avatar
Beezr
Beezr is offline
Default 2012 Oil Consumption
I was just curious about how much oil my engine should use. I asked a friend who has a 2011 103 and he said his uses oil and didn't think anything of it. Reason I ask is normally we don't like to see that when we check the stick on our vehicles. The last 2 metrics I had didn't use any but I was wondering if that's because they were water cooled. It appears mine uses about 2oz. in 200 miles of 70-80 mph. BTW I'm using 15W50 Mobil1 and my bike is completely stock.
Thanks in advance.
Old 10-06-2014, 08:27 AM
djl's Avatar
djl
djl is offline
Received 2,058 Likes on 1,516 Posts
Thanks in advance.
2 ounces in 200 miles = 1 quart in 3200 miles, or a quart between changes. I would consider that excessive for a motor I built but, truth be told, it's not unusual or abnormal oil consumption.
Old 10-06-2014, 04:25 PM
Beezr's Avatar
Beezr
Beezr is offline
Thank you. It's probably less than 2oz/200 but I guess they all use oil somewhat and mine is probably in the normal range.
Old 10-10-2014, 11:27 AM
qtrracer's Avatar
qtrracer
qtrracer is offline
Check it after 1000 miles.
Old 10-11-2014, 10:13 PM
Lu's Avatar
Lu
Lu is offline
Beeze, next oil change, go synthetic.
Old 10-11-2014, 10:57 PM
ynots's Avatar
ynots
ynots is offline
If your running it at the full mark (hot check) try running it in the mid range and see if you notice a difference.
Old 10-12-2014, 09:49 AM
Beezr's Avatar
Beezr
Beezr is offline
It is synthetic Lu.
Old 10-12-2014, 09:52 AM
Beezr's Avatar
Beezr
Beezr is offline
That's the mark I was trying to maintain ynots. Maybe I'm being too fussy and with cold weather coming in I won't really be able to make an honest evaluation anymore this year. I'm sure there's nothing wrong with my engine and others may use more but from what I see they all use oil because they are air cooled and that's what air cooled engines do.
tekeum
08-22-2017 05:19 PM
94 ultra
Engine Mechanical Topics
17
01-17-2017 06:46 PM
Streetrunner
08-02-2014 11:58 AM
Bbbadboy
11-03-2013 08:43 PM
Diesel-Dawg
06-22-2011 07:12 AM
Quick Reply: 2012 Oil Consumption
