Lower gears or mild cams ???
Old 12-11-2014, 07:58 AM
martin10's Avatar
martin10
martin10 is offline
Default Lower gears or mild cams ???
14 Softail with stage 1 kit and tuner. Looking for a bit more acceleration. If you were doing only one would you go with. Lower gearing or mild cams? Just cannot make up my mind on this and will only be doing one or the other. I ride on back roads in the Blue Ridge Mountains with very little highway.
Old 12-11-2014, 09:10 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
I wouldn't gear it,as you`ll be sacrificing top end. do a mild build to the motor.that`ll give you acceloration
Old 12-11-2014, 09:40 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Andrews 48's.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 12-11-2014, 05:45 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,811 Likes on 3,315 Posts
Default 6spd trans
So if your running a 6 speed trans with a final drive of 2.79:1 it wouldn't hurt to change the final ratio a bit with a bigger rear pulley but you'll probably have to change the belt as well, its a reasonable price change. There are calculators on line to help you get what you want based on what u have..
Old 12-11-2014, 06:26 PM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
You can make a 2 tooth count change w/o a new belt. Stock gearing on these 6 speed bike SUCKS.....they're freakin turds!
First I did the front 30t from the stock 32t, which I had to then pull the wheel back. Incredible upgrade for the money. You can actually make the 6th gear semi useful.
Then I decided on adding the 70t rear and WOW.... Freakin awesome!!!!! Torque feel is just night and day from stock.
At 80mph I'm at around 3,200rpm.
Old 12-20-2014, 08:15 AM
johnnyjellybean's Avatar
johnnyjellybean
johnnyjellybean is offline
If you go with the Evolution Industries 30T front engine sprocket, you'll land up with a final drive ratio of 3.165:1. You will still have an accurate speedo and it's much less work. Best bang for the buck mod you'll do. If you think it's too high( a 5 speed is 3.15:1) then you can always add a 64T sprocket to the wheel
and bring it down to 3.07:1 (3120 rpm at 80mph)
Now if you were to do the cams too..........................
fwb35
06-20-2014 08:43 AM
SlimsSG
11
07-27-2012 09:20 AM
keogh
02-13-2012 12:45 PM
rredneckn
Touring Parts
04-23-2010 10:27 PM
Duff
07-09-2009 06:17 PM
Quick Reply: Lower gears or mild cams ???
