Exhaust Leak!!!!
exhaust leak
i know the feeling. try to loosen everthing again. to include the bracket bolts. and alternetly between the bolts retighten them again. go between the two heads. then clamp down the braket bolts. i had the same problem. it just didnt like the way it was clamping down. when i loosed it back up and jiggled it up. i noticed during tighting process it angled itsself up a little differently. leak fixed.. by the way if you have like a halloween smoke fogger. you put that thing close to the joints and watch exactly where the leak is. hope that helps.
LCCXL1200X
2014-2023 Touring Models
03-27-2016 01:57 PM
