Push Rods
Push Rods
I am installing Andrews TW37b cams with CP M5011 Pistons on my 2000 FXDL 88ci. I am switch to a Cometic MLS head gasket to help control the higher compression. I would like to stick with the stock push rods. The base circle on my stock cam and the Andrews cam are the same. Can I put the .0045 MLS head gasket in and be ok or should I play it safe and install the .0051 MLS gasket?
Thanks for reading and let get some dry weather!
10.2 static CR and near 200psi CCP is a bit much for those cams. Be prepared to run premium fuel and listen for detonation when summer heat comes along. A .030" head gasket would help mitigate against detonation but would bump comression up to about 10.5 which, IMHO, is OTT for those cams and the motor would be a ping monster.
EFI or carbureted?
Rejet and you will be fine. You might consider an aftermarket programmable ignition like the DTT unit so you can play with timing.
You are fortunate to be able to run fuel without ethanol, dang near impossible to find in my neck of the woods. You should be happy with that setup; you need the compression to get the most out of the 37 in an 88" motor.
All Kwik Trips in Wi have ethanol free premium. Some other gas stations are doing the same. Where are you located?
I measured the deck height last night and it is at .003. Stock is 190 main jet and 45 skow speed. I'm going with a 200 and 50 and already put a different needle in.
I think I would start with a 48; the needle will be the key. I live in south Texas where you would think you could find ethanol free gas. My 107" hipo motor will run fine on 87 and while I haven't had any issues with ethanol fuel, I would like to find some real fuel.
I run a CV44 on my all bore 107" with a Yost kit and run a 210 main and 48 slow, their emulsion tube and adjustable needle; works well and very tunable. Drilling the vacuum port and installing a lighter spring improves throttle response.
We prefer a good adj pushrod to load the lifter properly (.140-.150") to maintain quiet engine operation at full operating temps.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
SportbikeCO
Engine Mechanical Topics
16
03-06-2017 09:44 AM
