Swapping to thin head gasket on cammed TC96?
Old Feb 28, 2017 | 10:31 PM
SportbikeCO's Avatar
SportbikeCO
Default Swapping to thin head gasket on cammed TC96?
I recently upgraded my 2008 FXD TC96 with a set of SE204 cams and am really liking how it made the bike run compared to stock. I was wondering if there is a bit more to be had and was thinking of swapping to a thinner head gasket to achieve higher compression & improved squish band.
Cometic told me they would sell me a .018 MLS head gasket so I plugged it into the big boyz calculator and got the following data. Stock VS the .018 keeping all else the same.
Would it be a worthwhile upgrade to swap this out to gain the .55 points of compression for the $50 the gaskets cost? (i already have adjustable pushrods)
Any problems running such a thin gasket on these motors?
I live in colorado at 5200' elevation and often ride around in areas around 8000'.
data from the calculator:
.045 head gasket (stock)
Static Compression 9.25:1
Cold Cranking Compression 178.1@Sea Level
Cold Cranking Compression 153.4@5200 Feet Above Sea Level
With .018 head gasket
Static Compression 9.80:1
Cold Cranking Compression 191.8 @ Sea Level
Cold Cranking Compression 163.5 @ 5200 Feet Above Sea Level
Old Mar 1, 2017 | 06:47 AM
prodrag1320's Avatar
prodrag1320
you really want to cc the heads to find out exactly where your at in reality,compression wise.have the heads milled for desired compression with .030 head gaskets (204`s get set @ 10.0-1 here).018 is too thin on a street motor,IMO
Old Mar 1, 2017 | 07:12 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
With an .018" head gasket, I'd bet good money you'd be swatting the head with the piston carbon in very short order.
Bore to 103", with a .030" and kill 2 stones with one bird.
Scott
Old Mar 1, 2017 | 07:14 PM
Max Headflow's Avatar
Max Headflow
Make you you get the bike tuned anyway you go.. Will likely need to add fuel and pull timing.
Old Mar 1, 2017 | 07:54 PM
SportbikeCO
Scott
what is an ideal squish distance to maintain on a street motor? Any reason I can't do this dirt bike style and use solder and order my gasket to the ideal spec?
im interested in doing it partially because the cost would be so low as I'm doing the wrenching, and no downtime for sending the heads out.
Old Mar 1, 2017 | 07:56 PM
Jay Guild's Avatar
Jay Guild
+1 your heads are probably around 88 cc instead of the reported 85 and .030 is the lowest I would go on a street bike
Old Mar 2, 2017 | 07:28 AM
Hillsidecycle.com
Sponsor
.030".
We used .020" on our AHDRA Mod Class racer years ago, no carbon whatsoever, and trust me, you don't want it any closer.
Scott
Old Mar 2, 2017 | 08:32 AM
billib1954's Avatar
billib1954
Not to change the subject, but what is piston to valve clearance on a 103". Would I need to check clearance if I go to a .030 for a little cheap compression and would it be worth it? Andrews 54 cams are installed. Thanks, Bill
Old Mar 2, 2017 | 11:32 AM
djl's Avatar
djl
.030" as previously posted. JMHO but pulling the heads to install a .030" head gasket is not worth the effort unless head work is part of the plan.
Old Mar 2, 2017 | 11:36 AM
djl's Avatar
djl
what is an ideal squish distance to maintain on a street motor? Any reason I can't do this dirt bike style and use solder and order my gasket to the ideal spec? im interested in doing it partially because the cost would be so low as I'm doing the wrenching, and no downtime for sending the heads out.
The heads are coming off anyway, so clean up the chambers and measure chamber volume yourself; you need a baseline. Gasket choices are limited, off the shelf anyway, perhaps you could have a "custom" set made; don't know. Typical off the shelf thicknesses are .045", .040", .030" and .027". As has been posted, anything less than .030" P to V clearance is pretty tight.
