SE 260 cam
I think that cam is on the aggressive side of things. Im not a pro, maybe others will chime in. Do an internet search on cam grinds and what the numbers mean and you will probably draw your own conclusion. I think the lift is around .600 which is not really bolt in if it is. Jmo..... remember I said I think, not I know.
The cam will "bolt in" but there are many better choices. A set of SE 204 would be a much better choice if HD cams are a must. Andrews 48 is about as good a cam for a "cam only" upgrade in a Stage I 96" motor. You will be much happier with either one; the 260 will turn the bike into a turd.
I also would point out to you that multiple knowledgeable HD engine people have told me that revving a Softail past 6000 rpm is a bad idea, as the inertia of the balancing system used is immense, and puts a great deal of stress on the pressed crank at high rpm and at high rpm shifts. You could end up "scissoring" that crank, which would then manifest as greatly increased engine vibration and possibly much worse.
Furthermore, I suspect the SE260 cam overlap would result in way too low dynamic compression, so the power gains targeted by that aggressive cam timing might be greatly reduced. That cam normally requires high compression pistons.
The SE 260 is a cam designed for high rpm operation. Your soft ail configuration (as I described above), your intake manifold, your stock pistons, and your stock heads all make the 260 pretty far from a good choice. A $50 or $200 saving on a set of cams is meaningless in the overall cost of building an engine that can actually USE aggressive cams. And, I suspect your performance with all the stock components I listed above would be very disappointing.
I would advise very strongly do not do this.
Jim G
As for the Andrews cams listed in your above post, the 48 is the best fit; all the others listed require more compression. With the your A/C, exhaust and tuner, you have a good platform; the 48 with a re-tune will make a nice runner.
It'll never make power up at 6500 with an un-touched OE head anyway, in spite of a wild cam.
An Andrews 48 is a VERY GOOD plug/play cam for a 96" engine.
Once tuned, with a good exhaust system, most tuners can show at/near 90 hp and 100 ft/lbs.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
