Valve size upgrade
Old 08-28-2014, 10:34 PM
kblhd's Avatar
kblhd
kblhd is offline
Default Valve size upgrade
At what point does it make sense to go to a 1.90 intake and 1.610 exhaust valve? Getting ready to have my standby heads ported and wondering if there will be much of a difference in oversize valves with my current setup.
Old 08-29-2014, 07:08 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
just about any twin cam build will benefit from 1.900 intakes.if ports & seat area are properly shaped,a 40-50 CFM increase can be seen which equates to big HP/TQ gains.make sure whoever is doing your heads the difference between porting for the bigger valves & not just installing bigger valves (which will gain almost nothing)
Old 08-29-2014, 11:08 PM
kblhd's Avatar
kblhd
kblhd is offline
Don't want to have the heads ported with stock valves and then find out they should have bigger valves, then have to take them off and redone. Thanks for the post.
Old 09-01-2014, 06:37 PM
GraemeR's Avatar
GraemeR
GraemeR is offline
A chap called Des Hammill wrote a very informative book where he covered off a setup/design using larger intake valves.
The book is called "How to Power Tune Harley-Davidson 1340 Evolution Engines for road and track" (ISBN 1-874105-88-X)
I'm planning to use his porting theories on a spare set of heads I have lying around.
cheers
Old 09-01-2014, 11:40 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is online now
Received 1,811 Likes on 1,064 Posts
More air in+more air out=more power. Simplicity at it's finest. Talk to as many shops that you can handle, take notes, and then go with who will give you the best results to match your riding style.
Old 09-02-2014, 08:08 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
When really looking for it, as far as big hp is concerned, age-old engine building info always refers to the intake valve size approx. 1/2 the size of the bore, and the exhaust about 75% of that.
Not only the valve size, but the shape of it, and how the seats are cut that can GREATLY enhance cylinder head flow.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 09-02-2014, 11:45 PM
kblhd's Avatar
kblhd
kblhd is offline
Like it says I currently have the Andrews 26. If I go to another cam I do not want to have to pull the heads and do them again. Maybe an Andrews 37 at some point or higher ratio rocker arms for the 26? Looking at 81 or 82 cc heads when I am done.
Old 09-03-2014, 08:18 AM
Hillsidecycle.com
Sponsor
Our 98"er's/Andrews 26/9.6 cr/Stage II heads will post 93-95 hp and 109-111 ft/lbs, carbed, with a Supertrapp 2/1.
Torque is usually all in by 3500.
Those VH pipes won't do you any favors.
Scott
Old 06-06-2016, 08:33 PM
dbr1990's Avatar
dbr1990
dbr1990 is offline
Scott[/QUOTE]
That is on point
Old 06-08-2016, 08:28 PM
GraemeR's Avatar
GraemeR
GraemeR is offline
Ummmm..The thread is 2 years old matey!
txphatboy
Engine Mechanical Topics
13
05-30-2021 04:20 PM
02fastdyna
09-17-2015 10:40 AM
SURFOR Chop
Exhaust System Topics
04-07-2011 12:01 PM
skruzluce
11-08-2009 04:31 PM
timberland
01-22-2008 08:18 PM
Quick Reply: Valve size upgrade
