Andrews Cams
I bought my fltr with a ev23. It was fine and like Mr JZ says they a bolt in cam and will make you happy, not super duper elated. They go in easily, reuse the stock rods. Really not too much fuss. I got a hold of a Wood w6 and will say the only, and I mean only one, drawback is the w6 is noisier. It is superior in every other way, seat of my pants tells me so.
Good luck,
Tom
Good luck,
Tom
Good luck,
Tom
Good luck,
Tom
I can live with that kind of noise
Good luck,
Tom
Good luck,
Tom
Just asking, I'm sticking with what I ordered, but do like to understand it all.
When I was picking a cam, the W6 is a hair over .5 lift, I thought .5 was the limit on bolt in cams? The w6 and the evl3020 have the same duration at 240 with similar overlap, 36v38, but the 3020 is .5, I went 3010 over the 3020 with 234 234 because I wanted more low-mid. When I was reading it looked like everyone with the W6 had headwork done along with pistons and some other mods to boost compression. So the W6 runs fine on an otherwise stock engine?
