Springer shock is loose...
Old 04-27-2015, 04:13 AM
shimaze's Avatar
shimaze
shimaze is offline
Angry Springer shock is loose...
I am not sure what is wrong with the springer shock. All I did was take it off to replace the crusty bolts with some shiny new stainless hardware. I went to put it back on and noticed that I could not tighten it down enough to get the shock to tighten up. I know that I cannot crank the hell out of the bolt and bend the shock mounts in close enough to keep the shock from shaking. Putting too much pressure on the bolt could break the tabs for the shock mount. If that happens, the springer front end is ruined!
So, I tightened up the bolts to a reasonable amount of torque and then took this video. I left the 36" breaker bar, 3/4" drive nut buster ratchet, and the 780 ft/lbs impact wrench in the tool box and thought it would be best to get some ideas of what to do next?
There was nothing at all wrong with the shock before I messed with it. It was nice & tight and worked just fine. Something changed when I took the bolts out and the shock off. It only had a couple of washers on both sides of the bolt (top & bottom). I didn't see anything else and nothing seem to just fall out.
What am I doing wrong?
Before I took the shock off
After I took the shock off
Old 04-27-2015, 03:20 PM
Joe_G's Avatar
Joe_G
Joe_G is offline
Did you accidentally swap the bushings top vs bottom? I'd have thought they are the same, but it looks to me like you installed the bushings incorrectly from all that slop back and forth in the bracket you are getting.
Old 04-27-2015, 03:23 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,817 Likes on 3,319 Posts
Looks like a bushing issue. Is it in there?
Old 04-27-2015, 03:39 PM
glidein wide's Avatar
glidein wide
glidein wide is offline
Was there a sleeve that stuck to the bolt making the new one sloppy?
Old 04-27-2015, 04:48 PM
Bad-Dog's Avatar
Bad-Dog
Bad-Dog is offline
Possibly a spacer in the rubber is missing or the original bolts were stepped
Old 04-27-2015, 04:58 PM
glidein wide
It looks like two different bikes!!!
Old 04-27-2015, 07:41 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,245 Likes on 5,408 Posts
Old 04-27-2015, 09:53 PM
CDF346's Avatar
CDF346
CDF346 is offline
Replace the shock. The bushing( rubber) rot out. When you drove out the bolts the rubbers took a ****. You cannot to my knowledge, replace the shock bushings.
BigT-91
04-09-2016 08:10 PM
reservoir dog
01-15-2013 06:57 PM
J73
04-19-2012 09:01 PM
tipiman
08-25-2011 06:35 PM
ckamin
06-06-2006 01:34 PM
Quick Reply: Springer shock is loose...
