Need a crimping tool
I've been using the Sargent 1028 CT
Thanks for all of your suggestions. Sorry I haven't responded sooner, been neck deep in this little project. I have run all new wiring through the frame so I won't have this issue again. Found a crimping tool at Radio Shack that is doing a fair job, have only had to redo 2 pins. I'm waiting on a new fuse block (there were NO fuses in the original wiring) to get here. I'll have it Tuesday. I hope to be at the point that I only have to plug in 4 wires to the fuse block, install the battery and ride on. Thanks again. Pothole.....
Solder vs Crimping
Not to take this conversation in a different direction, but, I am about to do a wiring extension on my 86 FLH for apes. I was just going to solder and heat shrink, but the harness extensions came with crimps. Any reason i should us one over the other? It seems to me the solder will have a lower profile and be less bulky and less apt to slip.
Would love to hear some thoughts on this.
This could be as bad as an oil thread. I played with boats quite a bit until I got back into bikes. There's some good reasons to crimp in a high vibration application, ABYC standards notwithstanding.
http://www.marinewireandcable.com/20...cable-and.html
