Intake leak symptoms?
98glider,
A lean running engine will make poor power, run hot and generally make you mad with it's limp performance.
One quick test is to take the bike out and as you are cruising along, back off on the throttle. If the bike has a quick surge of power as you do it, it is most likely running lean.
It is more pronounced if you do it from a wide open throttle but that is not always a practical test to perform what with traffic and all.
Another thing to look at is the spark plugs but I am not qualified to help you "read" them for a slightly lean condition because Evos can have very clean looking spark plugs but not be running too lean.
Maybe someone else on here can help you with analyzing your spark plugs.
You say your bike is running okay so maybe you don't have any problem at all.
If your bike feels okay to you, no sense getting worked up about whether it "might" have a problem.
Update: intake seals done. Found bad o rings on carb. Guess bad o rings was why slow acceleration and coughing or semi backfire . Sure hope so. Will pick her up fri or sat depending on weather . Here in Houston 20 inches of rain since may 1st. Sorry bad o rings on accelerator pump.
