Ironhead A place to talk about Ironheads.
carb pop
Old Nov 7, 2009 | 09:04 PM
lagunatic's Avatar
lagunatic
Default carb pop
i thought I would throw this out here ,my 71 has started poping out thru carb when Iam between exceleratating and deexceleratating even when warm but not when cold and choke on a bit.its not bad just dont care for it.
Old Nov 7, 2009 | 09:36 PM
IronMick's Avatar
IronMick
I believe [but i do not know for certain] that popping out the carb is typically a lean condition. First thing to check is intake and exhaust leaks. Here are my notes ...
Intake And Exhaust Leaks Tests
You cannot get a good tuneup if there are intake leaks or exhaust leaks.
1. Check for Intake Leaks
With the engine idling spray propane gas or WD-40 around the carb/intake/cylinder head joints. WD-40 is said to work well because it has very fine spray droplets. Propane is best because it leaves no mess, and is most easily sucked in thru leaks. Be careful to not allow any of either to get sucked in thru the A/C as this will invalidate the results.
Any change in engine RPM is a leak which must be fixed.
EDIT: Experience is that this procedure will identify larger intake leaks, but it may miss very small leaks that also must be fixed. And that propane is definetly the better choice.
2. Check for Exhaust Leaks
Pour about 1/2 ounce of oil into each cylinder thru the spark plug holes. Run the engine at idle. You will get lots of smoke for about 5 minutes.
All smoke should come from the ends of the exhaust pipes/mufflers. Any other is a leak which must be fixed.
Old Nov 10, 2009 | 12:13 PM
d_slat's Avatar
d_slat
yup, sounds just a touch lean. did you say it backfires when you close the throttle? try turning the idle mix screw out 1/8 to 1/4 turn and see what it does
sj032885
Ironhead
Apr 3, 2014 09:41 AM
PJRED70
Ironhead
11
Feb 26, 2013 08:03 PM
thebearddavid
Ironhead
18
Mar 4, 2010 08:33 PM
ironsport83
Ironhead
15
Sep 4, 2009 08:44 PM
1stsporty
Ironhead
15
Jun 17, 2009 09:57 PM
