Newbie 87' XLH883 RPM/MPH question...
I recently got a stock 87' xlh 883 standard sportster which only came with the stock speedo and no tach. I know most people on the forums state you should shift by feel, but being a new rider (I literally graduated the Harley MSF last weekend and got my class M endorsement Monday), untill I can cough up the dough for a tach, roughly what speed should I be shifting at? It's an stock 87' XLH883 standard model candy blue, no mods, with the 4speed Evo. Any info would be greatly appreciated!
What speed you shift at is dependent on the load you're putting on it. Run it wide open to the rev limiter and shift. Then you'll know what the maximum speed to shift at is. Anything less than that and you're leaving speed on the table. 90+ in third gear is a pretty good shift point, but you'll likely want to shift before that for routine riding. I seem to recall no problem doing around 60 in 2nd. But then I only rarely ride that one.
If you give it gas and it lugs, down shift. Otherwise, if you're cruising, up shift.
Anyway, you're worrying too much. Just ride it.
Hmmmm.....sounds fun........bwaaaaaaaaaa!
Thanks Doc! And thanks to everyone else! Rode it into work today I really pushed the RPM's and was amazed how fast I could get it up before it stopped giving me any more power in each gear.
Keeping her higher up in the RPM range than I was seemed to help a bit with the low speed (40mph) rear end shimmy/wobble I get on one leg of the route I take to work. I traded some items for from an old fella at work who is retireing next year who has a road king and a dyna, so it sat in his garage for a good long while thinking maybe the tire has a flat spot.
Anyway, Doc if you ever find yourself around Vandy send me a PM I'll buy you a brew and talk shop!
