spacer between compensator nut and rotor??
Old 10-27-2015, 03:21 PM
kino44's Avatar
kino44
kino44 is offline
Default spacer between compensator nut and rotor??
I have n early 1984 FLTC tour glide classic that im working on when I took the primary apart there was no spacer between the compensator nut and rotor? this bike has been rebuilt before so I cant base if that's factory or not? there was one between the rotor and main gear which I know is a must.My manual does not state if one is needed or not? what I want to find out is it required to have one between the compensator nut and rotor? I know they are needed for proper alignment of the primary chain mine seems to be good without one, I have heard some have bottomed out the compensator nut when torqued down if one was not used, is it a must regardless to have one between rotor and compensator nut??
Old 10-27-2015, 04:15 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,818 Likes on 3,320 Posts
Bolt it all up and put a straight edge across both the comp gear and the clutch basket gear if you have proper alignment your fine if not space to within .030". closer to .000' is best though.
Old 10-27-2015, 04:25 PM
kino44's Avatar
kino44
kino44 is offline
did all that im about 32 secs off my comp gear is a bit further out but to me I dont think that would really be a big deal but if I lose that spacer between the compensator and rotor Im good what I still need to know is it REQUIRED to run a spacer there?
Old 10-27-2015, 04:38 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,247 Likes on 5,408 Posts
Spacer under nut was used on older bikes but not in 84...check out the parts breakdown on Ronnies online.
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old 10-28-2015, 05:48 AM
kino44's Avatar
kino44
kino44 is offline
Default spacer
yea just found that out the old rotor types had a hump they did not need one I have a newer kit going on and the rotor needs a spacer they are flat,thanks for the info
Old 10-28-2015, 06:22 AM
98hotrodfatboy
Just make sure you chain has clearance from the Rotor....an 1/8" would be safe..
Old 10-28-2015, 08:34 AM
kino44's Avatar
kino44
kino44 is offline
Default clearence
I hear ya without the spacer it rubs the rotor now I know why the chain I took out had the rivets on the inside wore completely down was a mystery did not see what would have caused this now I know
thanks for your help
kino44
Shovelhead
10-28-2015 07:11 PM
robert1104
10-25-2015 06:30 AM
scoriden
03-27-2013 04:40 PM
sr_smyth
Exhaust System Topics
12-04-2012 05:58 AM
Evilution
11-08-2006 09:33 PM
Quick Reply: spacer between compensator nut and rotor??
