Extended Reach Brake Pedal
01-14-2016, 11:54 AM
Ive searched and do not believe that anyone makes an extended reach brake pedal for a bike as old as mine. I was thinking of adding an extension to a stock pedal and having it rechromed. Have any of you ever done this? I need my brake pedal moved about 1 inch forward. Thanks
01-14-2016, 01:14 PM
A latter model pedal is about 1-2 in longer.
I put one on mine just cause.
I wanna say it was off an 02 RK
Do some cking but mine was on Ebay
WP
01-14-2016, 01:29 PM
Mine has the skinny shaft with the splined end on it. All of the later ones I have seen were totally different but, I'll check again.
01-14-2016, 01:38 PM
That's real different even to my 97
Ummm Things that make ya go Ummm
Well ch!t Get a second pedal cut and weld them together to make one the length you want.
Chroming can be a bit expensive.
Good luck WP
01-14-2016, 01:47 PM
Yep. Thats what Im going to do. Luckily, my son in law has a welding business. If chroming is more than $100.00, I'll just paint it black.
01-14-2016, 03:05 PM
01-14-2016, 03:12 PM
Thanks . It doesn't look any longer than stock to me. Not sure why it is described as extended. Thanks for the heads up though!
01-14-2016, 08:55 PM
Quote:
Originally Posted by
IBDAGRIZ
Griz it has been awhile.
Hope things are good down your ways
Respects WP
01-15-2016, 08:01 AM
89FLHTC
That'll clean up fine! Measure yours and ask the seller how long his is.
Did I just write that?!
01-15-2016, 08:49 AM
Doing well WP. Just keeping my head up and strolling along here.
Griz
