O-Ring dimensions #11140 vs #11170
I have 4 O-Rings, two #11140 and two #11170 but they are mixed together, two are slightly larger diameter than the other two. I spent a lot of time looking for the dimensions but can not find them. The larger one's outside diameter is about the same as the outside diameter of the 45583-83 crush washer. They are about the same thickness. Parts manual shows two are for the fork caps and one is used on top of the fork cap for the front fork air control with a crush washer for the banjo bolt. ( opposite side shows crush washers only) This is on a '90 Ultra
Thanks in advance
joe
Thanks in advance
joe
