How do you remove the oil pump shaft bushing in this situation?
In process of replacing my oil pump on 97 flhtc due to drive gears shattering. I am going to remove motor to slide hammer the oil pump shaft out (very tight) but if its that tight, how do you remove the oil pump shaft bushing afterwards and is installation of bushing simple? Thanks in advance!!!
Griz
Yes and have the shaft out as far as I can without removing motor. Waiting on engine stand and all needed parts to arrive. Just trying to get info on it because it seemed it was going to be a trick being with all the effort to get shaft where it is now and bushing hasn't moved, seemed it should have moved some anyway being shaft that difficult to slide out.
Received 4,317 Likes
Didn't realize it wouldn't clear the tranny coming out of there with the motor still in the frame. That blows having to pull it to get it out.
Is there considerable wobble between it and the shaft you're pulling? May not need to actually replace the bushing or shaft.
Griz
Griz
Engine is ready to be put on the stand except 4 bolts. Both drive gears exploded, had to cut the drive gear off the pump shaft. The shaft is longer than the space between the motor and tranny so motor has to be pulled or twisted in frame. Just want to know after I get shaft out, what is the method to remove the bushing or sleeve the oil pump shaft runs through. There is no wobble or anything between shaft and bushing, very stuck.
Griz
