Ignition mods
Old 02-13-2017, 06:52 PM
jammerx's Avatar
jammerx
jammerx is offline
Default Ignition mods
I need to replace the hall effect sensor in my nose cone, 98 Road King FLHR, should I keep the sensor and the electronic Ignition and go with a Dyna 2000P or switch it out to a nose cone based Ignition like the S&S Crane Hi 4 or even the Mallory breakerless ignition with a mechanical advance? What have you used, and what has worked best for you?
Also I was going to change out the coil too, I see my choices are numerous, and I am thinking a higher voltage, single fire would be the best bang for the buck?
Old 02-13-2017, 06:59 PM
billib1954's Avatar
billib1954
billib1954 is offline
My Daytona twin tech has been working fine for 15 years if that helps any.
Old 02-13-2017, 07:20 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
If I had to change my cam sensor I'd go with a Dynatek 2000i.
Old 02-13-2017, 07:38 PM
flhchaz's Avatar
flhchaz
flhchaz is offline
Received 1,285 Likes on 499 Posts
I have used the Ultima it think it is 53-644 and was great. just make sure, what ever you pick it is compatible with your coil.
Old 02-14-2017, 04:24 AM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,743 Likes on 928 Posts
Did this two seasons ago. It is the same as the dynatek 2000i for less coin. No issues. Don't used the ultima coil. The stock coil is fine. YD
Old 02-15-2017, 10:08 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is online now
Received 3,704 Likes on 1,989 Posts
As you can see, we just love to spend your money here at the Evo forum.
jammerx (02-17-2017)
Old 02-17-2017, 02:26 PM
jammerx's Avatar
jammerx
jammerx is offline
It is all good... I like spending money on motorcycles... LOL! and I encourage you all to spend money too!
If I was going to just replace the nose cone sensor assembly, does any one have a good part number? I guess late model ones came with a bank sensor built in but you cannot buy those? Just put in the -94 one?
BassFace
Shovelhead
13
07-26-2017 02:53 PM
Poacher1967
Shovelhead
13
09-24-2015 07:07 AM
bigdan65
12-11-2010 05:08 PM
kathygill12
07-20-2010 11:08 PM
badinfluence63
08-08-2008 10:07 AM
Quick Reply: Ignition mods
