Early evo cruising speed?
Old 02-21-2010, 08:56 PM
oldshovelrider's Avatar
oldshovelrider
oldshovelrider is offline
3rd Gear
Default Early evo cruising speed?
How fast (RPM) can I run my '84flhtc all day long? This is my first EVO, (pans and shovels my whole life) and she feels fine at 80 MPH , about 3500 RPM, but I don't want to push her too hard. This is the early motor with the shovel lower end. I never cruised the shovels much over 70 because it was hard to hang on and keep my feet on the boards any faster.
Old 02-22-2010, 03:56 AM
dc1450's Avatar
dc1450
dc1450 is offline
It'll do 80 all day long for 100,000 miles, enjoy.
Old 02-22-2010, 09:13 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,707 Likes on 1,343 Posts
With my 79 FLH POS, I found that for every 10 MPH over 55 I cruised while on the road, it required one additional hour wrenching that night.
With my 86 FLHT, I've set the tach at 4000-4200 in 5th, left it there and run it 1000 miles like that. 80 is no problem at all.
Old 02-22-2010, 05:03 PM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
I must be getting old, for some reason at about 65, I keep trying to grab another gear on my 90 fxrs.
Old 02-22-2010, 06:05 PM
paul 1963's Avatar
paul 1963
paul 1963 is offline
i run mine 70 just to cut it a little slack it's 24 years old
Old 02-22-2010, 06:26 PM
Ultra89Rider's Avatar
Ultra89Rider
Ultra89Rider is offline
On my 1985 FLHTC, I cruised across country for years at 75 to 80 MPH with no problems. I had over 125,000 miles on it with no motor work before it was stolen. I even tried cruising at 90+ but found that the mileage I received was so bad it was not worth the expense.
Old 02-22-2010, 08:23 PM
I8SMK4U's Avatar
I8SMK4U
I8SMK4U is offline
My sleds a '94, i put a "1" tooth larger drive pully on the trans. Lost a little low end but It feels like my gears went from 1-5 to 2-6. At 70 my sleds not eaving breathing hard.
Old 02-22-2010, 09:30 PM
Hackd's Avatar
Hackd
Hackd is offline
3500 rpm extended cruising, should pose no long term effects, normal and routine maintenance being followed. I have made numerous trips from SE Michigan to Central Florida along I-75, and will normally run at 70-80 mph continously. A bigger issue with my FLHS is the large windshield that makes speeds in excess of 80 mph a bit tiring to maintain, as the bike requires a bit more 'attention', due to buffetting. I'm much more relaxed at 70-75 mph.
My FLHS is the same. When I'm doing 75, I'm thinking a 500 rpm reduction would really be nice. Perhaps a final gearing change is in the future for my scoot.
Old 02-23-2010, 08:09 AM
Buddy WMC's Avatar
Buddy WMC
Buddy WMC is offline
Know what you mean, so I installed a Baker six speed. 2800-2900rpm@85mph on the Interstate.
Old 02-26-2010, 09:09 PM
1skrewsloose
No joke eh? And you still get the low end grunt? I might seriously consider that option. Always seems like there's enough power to pull higher gears.
Quick Reply: Early evo cruising speed?
