evo case boring
Old 03-05-2010, 08:13 PM
cthecope's Avatar
cthecope
cthecope is offline
Default evo case boring
can an 87 evo case be bored to accept a 96" big bore with no case integrity problems?? i know some cases from the 90s had problems..thnx in advance...ced
Old 03-06-2010, 10:07 AM
miacycles's Avatar
miacycles
miacycles is offline
Anytime you bore out an Evo case to accept the big bore cylinders, you can run into problems as there isn't a lot of meat left. The problem is even worse with the '13/16th" cylinders. Aftermarket cases aren't that expensive and they have extra meat in all the right places.
Old 03-06-2010, 10:14 AM
gsxrboy96's Avatar
gsxrboy96
gsxrboy96 is offline
couldnt agree more, i recently purchased a set of delkron cases for 700 off ebay....... much better quality than factory hd stuff.
Old 03-12-2010, 04:46 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
I wouldn't do it! Later evo cases have more meat on them that yours. You can stroke your motor to 89", which I did to my 1990, otherwise fit later cases as suggested. When I started looking at doing that for my original motor I decided it was not much more cost and less trouble to fit a fresh motor. I am running an S&S 107 now, so be warned - messing with motors can get expensive!
Old 03-12-2010, 05:07 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
we`ve bored 100`s of stock cases over the years,3.625 & 3.812,zero problems.youll have no prob going 3.625 with your cases
Old 03-12-2010, 07:26 AM
89 fxrt's Avatar
89 fxrt
89 fxrt is offline
And what would be the cost of boring the cases???
Old 03-12-2010, 08:04 AM
95fxdl's Avatar
95fxdl
95fxdl is offline
My local Indie put a 96" S&S stroker in my "95 evo. No problems at all.
Joedirt69
EVO
21
12-20-2022 06:22 AM
bbqbiker
Engine Mechanical Topics
04-15-2015 05:43 PM
rewstr
EVO
07-10-2010 06:23 PM
pharmerkdm
Exhaust System Topics
03-02-2009 12:39 PM
Rebel78
01-19-2009 05:44 AM
Quick Reply: evo case boring
