EVO Rebuild costs
Old Aug 15, 2013 | 08:53 PM
Joedirt69's Avatar
Joedirt69
5th Gear
Default EVO Rebuild costs
Anyone know the cost of a dyi evo rebuild? had it rebuilt 4 k ago but just broke the crank....
Old Aug 15, 2013 | 09:29 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Costs vary depending on what you do.
Old Aug 15, 2013 | 09:32 PM
traildog's Avatar
traildog
Man, WHY am i hearing "I'm your sister, I'm your sister"
Old Aug 15, 2013 | 09:37 PM
Bumpandrun's Avatar
Bumpandrun
1800 to 5600 all depends how screwed up and what your comfortable doing. Crate motor might be the way...
Old Aug 15, 2013 | 10:14 PM
texashillcountry
Dirt don't hurt
TD you are getting scary man!!!!!!!!
When did you start hearing voices?
To the OP are you planning to do the work yourself or are you going to have a shop do it?
Old Aug 15, 2013 | 10:32 PM
cowboy 51's Avatar
cowboy 51
darn , don't think I've ever heard of a EVO braking a crank before , Did it brake the cases as well ? might just go with a crate engine what kinda of HP where you putting out with your engine ?
Old Aug 16, 2013 | 12:08 AM
Ken Oaff's Avatar
Ken Oaff
I have
The later 3 piece cranks have been known to break
Axle shafts require a higher grade of steel than flywheels
This steel is more expensive
Chances are the grade of steel used for the 3 piece crank was possibly compromised as a cost saving measure - this is only a theory maybe somebody with inside knowledge would be able to confirm this or otherwise
Old Aug 16, 2013 | 05:15 AM
grbrown's Avatar
grbrown
Red face
Joe, it would help us to know in what way the crank is 'broke'! If a bearing has failed you may be lucky and be able to rebuild the bottom end. If the crankshaft has suffered a fracture, the damage is likely to be much more extensive. It's difficult to answer your question and may not be possible until the engine is dismantled.
Old Aug 16, 2013 | 05:48 AM
Tom84FXST's Avatar
Tom84FXST
The first evos had the 5 piece "shovel" crank...somewhere around 86 they changed to the 3 piece design...and the first ones where notorious for breaking the pinion shaft...very common, even with stock HP.
Old Aug 16, 2013 | 06:52 AM
traildog's Avatar
traildog
Never saw the movie "Joe Dirt?"
