cam advise
I think that the two most commonly used "street grind" cams offered by Andrews are the EV13 and the EV27. The 13 gives more low end power through midrange without increasing the "redline". The Ev27 starts more in the midrange and allows about 500 rpm increase at the top end. This info is available on Andrews website.
go with the 13 do not use the 27 or anything else that has an intake close of 36/38 or higher UNLESS you plan on having good back pressure in your exhaust and a high flow intake (think two into one exhaust with baffles) If you are running open pipes, it will be pretty poor performance below around 3200 to 3800 rpm...
I was also under the impression that the EV27 was invented soley for use in heavy baggers and made phenomenal low end torque, and just happened to excel in lighter bikes as a happenstance to the fact it was so well designed? Please fill me in here before in put my cam in.
Neil
