Chh Chh Chh Changes
Sounds like a similar set up I had in my old FXR.
10.5:1 will be a bit much for the 27 cam.
Might want to consider a .040" head gasket, an Andrews EV46 cam, or, I ran in my FXR the V-Thunder 3030 cam, (which was a torque monster)
I currently run a V-Thunder 3040 cam in my bagger with 10:1 pistons, headwork, and have no issue at all with hard starts, pinging, etc.
Actually, a pretty good set up for a heavier bike.
I'm sure others will chime in with their thoughts as well.
There's another guy on here who has said good things about his set up with 10:1, headwork, and a Crane 326 cam, I think.....
Also, the SE heads that I bought new...the valve seals leaked right out of the box...might want to address that before you install them and have to tear it down again due to oil consumption. (...ask me how I know...) They will benefit from a quick clean up, (polish) as well. I found the SE heads to perform pretty well.
A 2:1 exhaust system wouldn't hurt, either...
Let us know how it turns out....
98 FLHX has covered alot of area, if you go with 10.5-1 comp, your going to have to let some air out of it with duration and late intake closing to control detonation down low or your timing will be so far retarded you will lose what you are trying to achieve and still possibly have the bag of marbles sound.
Next thing is the SE heads are limited to.575 lift.
what compression did your FXR end up at?
if your indy is recommending the wiseco 10.5 to 1 pistons, it will actually come to about 10.3 to 1, still to high for the 27, start looking at cams like the v thunder 3040, s&s 561, andrews 51, stuff like that, that will bleed off crankcase pressure sufficiently to run and not ping on pump gas, i helped paul put his fxr motor together, and with 10.5 to 1 and the 3030, it was a beast, but very borderline cylinder pressure, i believe he got away with it because of the weight of the bike, a larger bike would have probably detonated. you wont regret the piston/head combo, chad.
...and yes, it was a beast...
At 600 ft of elevation where I live, it was around 191 psi CCP.
As Chad mentioned, the S&S 561 would be a decent choice as well, and that was one of the cams I considered, but took a chance with the 3030, and it turned out well for me in that application. It really was an absolute beast...
Also, just FYI...I did end up replacing the stock starter with a 1.75kw starter, which spun the mill effortlessly...without compression release valves.
Night and day would be subjective, but an increase in compression will yield a difference, without question.
10.5:1 and the S&S 561 was a pretty common hot set up for a long time, and performs well.
The 561 has a bit longer duration, and a bit more lift. The EV51 would be a decent choice as well. Lots of choices....
I would think it (the 561) would be a bit softer on the bottom end than the 3040, but I'm basically running that set up, so my opinion is rather one sided.
http://www.nightrider.com/biketech/hplist_evo80.htm
