Thinking of doing the SE 95 kit with the SE 10.25 cast pistons. Would the 26g cam wotk with this setup without any ping? Also, probably going to have the heads ported so which head gasket would be best?
I have to agree with Allen.... That's too much for Andrews 26's.
HQ Heads (setup @ 10:1), HQ-0039's, and that FatCat you've already gotshoud easilyget ya 105/105 with torque over 100 @ before 3k RPM's. If you go 10.25:1, it'd be a bit higher.... but if ya can get it @ 10:1, why?
Is most of the torque gonna be up top or more in the middle? I would prefer to go with a setup that keeps the torque down low/middle as I rarely run in the upper torque range.
suggest you log on to Latus HD site and go to the "ask/Mike" in the service dept section. There is a ton of excellent info here and he will address your question(s) directly.
