adjusting clutch and primary chain
Old 06-19-2011, 12:48 PM
98glider's Avatar
98glider
98glider is offline
Default adjusting clutch and primary chain
Should I adjust clutch when the bike is warm or cold Also primary chain adjustment should the chain be measured from center of the chain slack
Old 06-19-2011, 01:32 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Best to adjust both cold.
Yes on the primary and check in several places.
Old 06-19-2011, 02:03 PM
95yj's Avatar
95yj
95yj is offline
+1
To elaborate, the chain will have tighter and looser sections. Rotate the chain so the tightest spot is in the middle and adjust to this spot on the chain. Don't adjust to the loosest spot.
Old 06-20-2011, 06:44 PM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
the manual for my 90 shows specs for hot and cold, but, like has been said, like doing it cold, why mess with all that heat of the motor.
Old 06-20-2011, 06:51 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
Originally Posted by 95yj
+1
I 100% agree manual says tightest in the middle and I think its 3/4 to 7/8 (no manual on my lap ). As for clutch adjust cold try it and readjust if needed and if readjustment is needed obviosly it will now be hot.
Old 06-21-2011, 03:42 PM
98glider's Avatar
98glider
98glider is offline
Thanks guys
Old 06-22-2011, 05:17 AM
Bama91's Avatar
Bama91
Bama91 is offline
I remember 5/8-7/8 on the primary. Lift the rear wheel or roll bike to 4 or 5 positions to check chain slack. Too tight in spots will not hurt it that's why the foot is plastic. It will wear before the sprockets will.
Old 06-22-2011, 10:01 AM
95yj's Avatar
95yj
95yj is offline
If you adjust the chain when it's on one of the loose spots, the chain will be too tight and you'll get whining from the primary. (Found this out the hard way quite a few years back.) It's true that your adjusting shoe will wear but that means you'll need to buy another shoe or on some bikes the entire adjuster. Also, the chain will stretch out and if you keep doing this, you'll need to replace the primary chain.
Too tight a chain is bad for your seals and bearings on the engine and tranny but more so on the tranny side.
Old 10-08-2011, 12:26 PM
DD06FLHRC's Avatar
DD06FLHRC
DD06FLHRC is offline
6th Gear
Default Whining noise in 3rd & 4th gear
I have an 06 roadking and recently replaced the stock cam tensioner with the screamin eagle preplacement chain kit. I have noticed a whining noise when I am at the upper end of 3rd and 4th gear. Looking for potential causes, such as primary chain, cam tensioner etc..wonderiing if anyone has any suggestions before I bring it to ann HD dealer.
Old 10-09-2011, 10:15 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Make sure it is not too tight. Read the earlier posts here about finding the chain's tight spot before checking tension.
Quick Reply: adjusting clutch and primary chain
