starter would not disengage
Went for a late night ride last night and when I started the bike the starter would not disengage. turned off the key and it was still turning over . tapped the solenoid to get it to quit and had to push start the bike to get it home. It melted the battery terminal. I will buy a new battery tomorrow and solenoid but should I be looking for anything else? Thanks 1989 fxr with a elbruto 113 and a ultima starter. the solenoid is separate from the starter.
Sounds like you are on the right track. Obviously once you take it apart inspect all the pieces for any ptoblems, don't forget to look at the ring gear. More than likely the solenoid contacts "welded" themselves together. Do you have "heavy duty" cables????
John
John
Check the wiring diagram, on some models there is always power to the relay.
Sent the starter to the reman shop it needs new brushes they burned . The spring in the solenoid broke and it had no push back. The poor contact stuck the disk to the contacts and overheated the wiring ends. I am replacing the battery cables to because I don't need a voltage drop. It take all the power I have to crank that 113 Ultima .
