Oil Pump Issue - TC88
03-08-2014, 07:33 PM
No odd vibrations or other signs of distress?
03-08-2014, 07:51 PM
They all do that!
03-08-2014, 07:57 PM
Not my bike, but none reported. Not sure he'd know.
Did he have an oil pressure gauge?
03-08-2014, 07:58 PM
Oh, I see, it's "normal" according to the dealer, right?
03-08-2014, 07:59 PM
How did the bearing surface look in the cam plate? Is it scored more in one area than another?
03-08-2014, 08:03 PM
I had a SE cam plate that I had to clearance the dowel holes as it didnt slide on to the pinion correctly.
03-08-2014, 08:26 PM
Quote:
Originally Posted by
tmanbuckhunter
Has to be trued and welded if he has gear drives, or it was one tight TC out of the box.
The ones I have done were all fine from the factory. Even when not you just set lash at the tight point and its fine.
03-09-2014, 01:51 PM
Any experience with Drag Specialties pumps? Supposed to be higher volume and certainly cheaper. Not wanting to go cheap, but if it's better as well..... why not. Most concerned with durability. The motor is totally stock.
03-09-2014, 01:53 PM
07+ OEM pump is ample for what you are doing.
