Is Dyno-tuning worth the cost?
He can't get them back...and I honestly think he's afraid to mess with it much more. He's very old school and hasn't worked on Evo's much. He prefers older engines.
This bike has had quite a bit of work done to it...it's far from a stock Harley.
I did check the intake gaskets...but I used WD-40. I really think it's something in the adjustments we made b/c it was running the best it has ever ran when I rode into his garage...and has been running like crap since.
As I have found myself, a dyno shop will check your bike before running it on their dyno, which will include fixing whatever may be wrong, if you let 'em. One of the beauties of a dyno is that it has raised the game where tuning shops are concerned. I suspect your bike, if you get it dynoed, will run far better than you expect of it - mine certainly does. Ignore the dyno-saurs (like that?!) who can't see the light!
I've dynoed many cars...as others have said, the dyno is a great tool to get the last bit of performance out of a properly running vehicle.
IMHO It is not a place to fix a broken vehicle which is what you have. It's like going to a heart surgeon to get a bone set. Maybe he can do it, perhaps he did it before, but it is not his specialty and his time is expensive. If bike dyno guys are like car dyno guys they are good at looking at what the sensors tell them and adjusting maps on a screen to optimize air/fuel and spark to avoid knock. I know, I tune cars. But often these guys don't know a carb from a muffler and have never actually adjusted timing by loosening screws...,they do their adjustments with a keyboard not a Allen wrench/screwdriver.
Make sure where you are taking it can fix mechanical problems which I think is your problem. And I'd try to get a list of what the guy did who messed it up. Your problem lies there if the bike was running great before he touched it.
You really should consider getting the bike running right before you start the dyno clock. If he dyno shop has great mechanics tell them to get it running right before they start dyno tuning the last bit out. Hopefully they will be honest with you as to their capabilities.
Hmmmm... Is the dyno worth it? I can't believe some are saying it's not. Maybe if the bike is stock, then yes, it's not worth it. If it's built, then hell yes it's worth it. Last thing you want is a lean running high compression air cooled V-Twin at WOT!! Putting mine on the dyno tomorrow morning!!
A dyno is a great tool to fine tune a well running bike, particularly EFI bikes that have so many optional settings. A carb and electronic ignition with a fixed curve, not so much because the tool has many features you cannot adjust on the bike.
I do agree that when you build up your bike, getting it on the dyno to fine tune AFR is very important - you're using the dyno's wide band and recording capability. On my car I installed a wideband and log the car's computer and wideband and make adjustments on the road and the track, that's not possible on a bike, so the dyno provides a convenient place to do that.
A dyno is not a tool to fix a broken bike.
ahhwataday
03-05-2012 08:12 PM
