Chugging noise - is it normal?
Old Aug 22, 2014 | 01:43 AM
unnnivers's Avatar
unnnivers
Default Chugging noise - is it normal?
Hallo, I'm in need of some advice!
Since I owned my FLHT, I noticed a strange (for me) noise from engine - it is like chugging or breathing and is noticeable from carb side. When I switch off the engine, there are some long chugs or "uffff" noise. Listen the video, there it is.
No any noticeable influence to engine output, no blowing somewhere outside heads, no oil consuption, no leaks. Heard it with injector and now after swapping hear with carb the same noise. 3 years still. Just curious, is it decides normal?
https://www.youtube.com/watch?v=Imlf...ature=youtu.be
Bike has 70k miles on, done some top end works - piston rings, base and head gaskets, valves grinding.
Old Aug 22, 2014 | 02:05 AM
M1dniterider's Avatar
M1dniterider
I don't hear anything that would concern me.
Old Aug 22, 2014 | 04:42 AM
grbrown's Avatar
grbrown
Your engine is a big air pump, I suspect all you can hear is air being drawn into the engine through the carb. Does it have a free-flow air cleaner and an aftermarket cam?
Old Aug 22, 2014 | 05:42 AM
unnnivers's Avatar
unnnivers
Wink
In generally I think so, but what makes me thoughtful I didn't hear so clearly audible chug from other harleys.
Yes, the bike has free-flow K&N air cleaner, Vance&Hines exhaust, but the cam is stock
Old Aug 22, 2014 | 05:53 AM
grbrown's Avatar
grbrown
Wink
The stock air cleaner that all Harleys come with when new is actually a silencer, so any change of air filter body will increase induction noise. I bought my 1990 Glide new and was surprised how noisy it was after I changed air filter.
Old Aug 22, 2014 | 06:09 AM
unnnivers's Avatar
unnnivers
May be it is a key. When everything is o.k. with the bike the owner often starts to see problems where they aren't. It's about me
Old Aug 22, 2014 | 06:37 AM
Maxdog2's Avatar
Maxdog2
Mine sounds very similar. As mentioned it's a big air pump and you are hearing air being drawn in after you shut the engine off. Nice bike.
Old Aug 22, 2014 | 07:42 AM
traildog's Avatar
traildog
Sounds good to me.........
Old Aug 22, 2014 | 07:53 AM
unnnivers's Avatar
unnnivers
Thanks guys nice to get opinions from Harleyland ! Love my bike and so sad feeling oncoming autumn. Rain, rain, rain...
Old Aug 22, 2014 | 09:02 AM
grbrown's Avatar
grbrown
Talking
We recently had a few days in Phoenix Arizona, where it was well over 100 degrees F, around 40C. Not very nice! Sun, sun, sun...
Jason Mcadams
Shovelhead
Oct 10, 2016 11:28 AM
Heza
Jun 8, 2015 07:31 PM
frozensoul
Mar 10, 2013 01:31 AM
missboy
May 15, 2011 10:25 AM
zyepod
Oct 22, 2008 08:18 AM
